Is it Mach 3 or VCarve 8.5
Postby kclayton » Mon Oct 23, 2017 5:59 pm
For over a year now I have been making signs at my Men's Shed with no problems.
I find the centre of the wood then zero. The machine starts goes up a little then comes down and starts engraving.
Last week the Z sensor was replaced and since then the machine does not work as it did.
I attach two files one before (YES)when things were fine as you can see by the red lines.
The one after(BOXLAUREN) shows quite a different movement from zero.
What have I done wrong? What do I check?
YES.crv
(478 KiB) Downloaded 34 times
BOXLAUREN.crv
(140 KiB) Downloaded 25 times
kclayton
Model of CNC Machine: Mach 3
Re: Is it Mach 3 or VCarve 8.5
Postby Adrian » Mon Oct 23, 2017 6:20 pm
Click the Set... button at the top of the toolpath tab and verify your home X,Y,Z positions. They are different in the two files and are the reason why the toolpath is starting where it is.
Postby tonydude919 » Tue Oct 24, 2017 9:04 pm
One file is .5 thickness and the other is .25 thickness.
Tony
tonydude919
Model of CNC Machine: cnc mako shark extended bed
Postby kclayton » Wed Oct 25, 2017 3:30 pm
Thanks Graham.
All is working well again.
I have no idea how that changed as it seems to have to be changed manually.
Thanks again
Kevin
kclayton
Postby kclayton » Fri Oct 27, 2017 10:20 am
Why did I say Graham?
Thanks Adrian.Kevin
kclayton
Users browsing this forum: richard@cnc, Yahoo [Bot] and 24 guests
