Can't rotate project
kevinbrown22
Model of CNC Machine: v90 fireball
Post by kevinbrown22 »
Hi,
I'm trying to make the Christmas sled from Nov. 2016. I have VCarve Pro 9. I need to change the XY for the runners and parts because it's too long for my machine the way it is. I've done this before (admittedly only once) successfully. When I try this the 2D moves but the toolpaths don't and recalculate tool path command doesn't do anything. Thanks for any help.
Kevin
joeporter
Re: Can't rotate project
Post by joeporter »
Did you rotate your material? You have to go back to the job setup and change the dimensions of your material to match the design and then recalculate the tool paths and load this on your machine as in the drawing. Hope this is of some help...joe
