- Example: Total depth of cut is .2" - start depth is .1" and depth of cut is .1".
Raise the Z height to .1, set to 0.0 and cut the first pass.
Then without changing the X or Y zeros, lower Z until it is -.1" and set it back to 0.0.
Cut the second pass.
Vcarve Inlay Rough Pass Cut Depth
Re: Vcarve Inlay Rough Pass Cut Depth
Why couldn't you lie to the machine by altering the Z height when cutting the first pass?
- Model of CNC Machine: CNC Router Parts Standard 2448
Sounds like it ought to work. I might play with that idea and see how it goes. I'm onto some other projects right now.
Thanks!
Tony
Thanks!
Tony
