Im using a 3d model from the clipart section in vcarve and have made it into a repeating pattern and want to pattern to stop and go around a vector.
Ive tried using the vector around component in the modelling tab and trimming that vector , which works as in the vector gets trimmed but the component doesnt
Is this even achievable in vcarve
Trimming 3d model to vector
- Model of CNC Machine: X-Carve
Re: Trimming 3d model to vector
Cutting components to vectors is an Aspire only feature. You can limit the toolpaths in VCarve by using vectors but you can't modify the component itself that way.
aah, ok.
