V-carving on slightly curved surface
- Model of CNC Machine: Shark
Re: V-carving on slightly curved surface
I have looked at code ripper but I am confused about the output Gcode file. Is it only for Mach3 or can it output other Gcode formats for other machines. I currently have a Shark and their compiler.
Mother Nature always bats last!
- highpockets
GCode Ripper works with Mach3 and LinuxCNC.
I have a friend that has a Shark. I think there is a probing software that is built in or can be added to the Shark. I know it will do 5 probe point, not sure if you can set more probe points.
- FixitMike
The Shark Virtual Zero uses 5 points to approximate a surface as a pyramid consisting of 4 triangles. I suspect that it would do a poor job of representing a spherical surface for VCarving.highpockets wrote:GCode Ripper works with Mach3 and LinuxCNC.
Click on steveibe and you will find the private message spot.steveibe wrote:I don't know how to view private messages?
Phil
Sorry, I probably should be posting this somewhere else.
I am still unable to view a private message, below is the message I get when I try?
Could someone please enlighten me.
"We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more to be able to use this feature."
"steveibe" link inactive, nothing happens.
- WaltS
- Model of CNC Machine: ShopBot 2418 - Spindle - ScottP Spoilbrd
You need to contact Support in order to be able to send and receive messages. I really don't understand why they just don't put that there as I've answered this question many times since I had it myself when I first started.
Thank you Walt !
I am STILL trying to view a private message.
I cannot figure out WHERE you contact a forum admin. or reach support.
Could someone please tell me what it is I am missing?
- highpockets
- WaltS
You're welcome. Sorry I forgot to post a link. HP had my back though.
New forum users (those whose names show in magenta) can't send or read private messages.
- dwilli9013
Adrian wrote:New forum users (those whose names show in magenta) can't send or read private messages.
Excellent info if I wasn't colorblind Adrian.........
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
Thanks guys, I feel silly, it never occurred to me to look outside the forum, I even looked in phpBB the forum software Co.
Hi Steve,
I'm not sure but Vectric may have set you up to post private messages. Your name is no longer red, at least that's what I am seeing.
Phil
Phil
