Aloha All,
My shop computer died prematurely after only months, I finally got Lenovo to send me a new one but I want to copy my old tool database and post file to the new install of Vcarve. I have both 8.5 and 9.0.
Can someone please tell me the file locations so as I may copy them to new machine. I have removed the old HD from the dead machine and mounted in an external case.
Mahalo,
Doc
My CPU Died, Got a new machine need some HELP
- highpockets
Re: My CPU Died, Got a new machine need some HELP
Look in C:\Program Data\Vectric\VCarve\V8.5 or V9.0. Don't have VCarve so my fold names may be a bit off, but you get the idea.
If the hard drive is good, why not just put it in the new computer?
Thanks I’ll look there.
I didn’t just swap drives because new one has Fast SSD drive.
- highpockets
Good reason. If your shop computer is like mine it just runs the CNC and there isn't much on it, but if you have a bunch of other stuff on it, you might consider cloning your old drive to your new one. Much quicker than having to setup a new computer. I know I've spent the last week setup my new office laptop!!!DocRock wrote:Thanks I’ll look there.
- dwilli9013
If the above is the case why not just leave that drive as a dedicated drive and run it as a slave on your new laptop.
You could boot into it whenever you want to run you machine and also when you want to run The Vectric software.
What I did is removed the CD drive from my laptop and replaced it with hard drive adapter. Went in and partitioned the drive removed all uneeded program files and junk.
Now I have a drive that is dedicated to running solely Aspire and a ton of storage space for all of my files pictures and drawings. Bonus is I can switch back over to the laptop main hard drive and do other media type things and mostly keep all the junk off of my dedicated drive.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
