Hi All,
I have a CNC mill with an automatic tool changer that uses a Fanuc OM controller. I have used VCarve 6.5 to program a part and tried both the Fanuc16 ATC and the Fanuc0i ATC post processors. Most of the programming works fine but it hangs up when it goes to change tools. Essentially it moves to the tool change height and stops but never proceeds to change tools.
Do you know if there are other Fanuc post processors available for VCarve Pro? Can the post processors be edited?
Kevin
Fanuc Controller Post Processor
Re: Fanuc Controller Post Processor
The post processors are text files and can be edited. There is a post processor editing guide on the Help menu for VCarve but I don't remember if it was on V6.5 or not. This link is to an older version - http://forum.vectric.com/viewtopic.php?f=4&t=6213
Generally the tool changing routines call macros setup within the controller software itself.
- dealguy11
What specific CNC machine do you have? There are some post-processors in the list (for example, the ones for Omnitech) that are for machines with Fanuc controllers. If yours is a name brand machine, you might find one for it. Note - I DO NOT suggest you just use the Omnitech post-processor without first confirming that it will work with your machine.
Steve Godding
