Hi there can someone help please. I am trying to create an outside profile toolpath for a part the programme will allow me to create a profile on the line but not outside or inside the line.
I have attacthed the file.
Bob
Cannot create toolpath
- Model of CNC Machine: 3 axis mill
- side plate.crv
- (30.5 KiB) Downloaded 64 times
Re: Cannot create toolpath
The large shape is an open vector. If you close it you should be able to do what you want as you can't mix open and closed vectors in the same toolpath with an outside/inside cut.
Hi Adrian
I thought i had closed the vector
Bob
Bob
Thanks Adrian all sorted now
Thanks again
Bob
Thanks again
Bob
