I just bought a Whiteside SC64 https://www.hartvilletool.com/product/9 ... outer-bits for engraving plastic signs (I hope).
Wondering how to add it to the tool list. Do I just pretend its a bullnose?
1/32" radius
1/16" diameter
7/8" cut length
Thanks.
Defining a "Conical Bit"
Re: Defining a "Conical Bit"
Define is as a Tapered ball nose.
- Model of CNC Machine: Shapeoko 3
When I ran this bit I ended up with some weird shoulders on the letters. Did I do this wrong?
Vendor Description My tool library entry
Diameter should be the wide diameter at the top of the taper. 1/4" shank.
- dwilli9013
Tool diameter should be .25 as 4D pointed out.
Taper should be 7.5 not 5.5
All else looks good.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- highpockets
I agree with the tool diameter, but where do you get 7.5 for the taper? The spec sheet show 5.5. Where is my math error?dwilli9013 wrote:Tool diameter should be .25 as 4D pointed out.
- dwilli9013
Good catch Johnhighpockets wrote:I agree with the tool diameter, but where do you get 7.5 for the taper? The spec sheet show 5.5. Where is my math error?dwilli9013 wrote:Tool diameter should be .25 as 4D pointed out.
My old eyes are missing the small stuff a bit more these days. Just grazing over text does not work anymore.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
