Last Pass Reverse Direction Not Working
Postby CosmosK » Sun Dec 04, 2016 4:11 pm
I wanted to use this feature cutting outside a profile. The 2D preview showed the arrows of the final pass going the opposite direction, but when I ran the file, it did not go the opposite direction. I check the G code and indeed the start and end points were not flipped as you'd expect. Is this a bug or a post processor issue? Thanks
Pen Marking Tools from www.cosmos-industrial.com
CosmosK
Model of CNC Machine: multiple
Re: Last Pass Reverse Direction Not Working
Postby IslaWW » Sun Dec 04, 2016 4:44 pm
Can you post the file?
CNC Technology & Training
IslaWW
Postby martin54 » Sun Dec 04, 2016 6:33 pm
Is this the first time you have used this feature ? I don't use it a lot but on the occasions that I have it has worked without any problem :lol: :lol:
If you can't post the file here for copyright reasons then consider sending it to vectric support for them to look at :lol: :lol:
Postby CosmosK » Sun Dec 04, 2016 6:47 pm
I can post it, just on another computer.. will do soon.
I have used it before, but I'm not sure I've been paying all that much attention to see if it actually reverses.
CosmosK
Postby Tailmaker » Sun Dec 04, 2016 7:22 pm
It seems to be a bit quirky and IMO not too useful for 2 reasons:
-It does not really do an additional last pass but rather uses the last layer pass. I.e. if you specify a total depth of 10mm, with 2mm depth of cut and 1 mm allowance, it will do 4 rounds that are 1mm oversize and a final 5th with z=-10mm without the allowance. I think it would be better to go down all the way with allowance and then do a real additional pass on target.
-It would be nice if it could run the additional pass with zero allowance just as a cleanup pass but if that is indeed chosen as zero the checkmark is ignored. However that is a minor issue because one can make the allowance very small like 0.001mm
Tailmaker
Postby martin54 » Sun Dec 04, 2016 8:48 pm
Tailmaker wrote:It seems to be a bit quirky and IMO not too useful for 2 reasons:
You could almost make it work how you wanted by editing the passes for the tool you were using, it's extra set up work I know but you could set the last pass to be a very small amount :lol: :lol: :lol:
I have used it a couple of times but most of what I do doesn't really have the need for a feature like this.
Postby Adrian » Sun Dec 04, 2016 8:52 pm
I never really use it as doing two toolpaths and using the merge toolpaths to make them into one toolpath is a much more powerful feature with more control.
Postby CosmosK » Sun Dec 04, 2016 9:17 pm
but if you merge them, how can you ensure the full depth pass goes last not first?
CosmosK
Postby CosmosK » Sun Dec 04, 2016 10:01 pm
Here is the offending toolpath. I've changed the tap file to be .txt so it will upload. You can see it does not reverse directions for the final pass.
example.crv
(23.5 KiB) Downloaded 52 times
example.txt
(1.6 KiB) Downloaded 70 times
CosmosK
Postby IslaWW » Mon Dec 05, 2016 12:59 am
Cosmos...
I opened your file and even the preview shows no reverse of direction. I added a rectangle (closed) vector, selected both, applied your toolpath parameters and it worked as expected (in the preview)
IslaWW
Postby Adrian » Mon Dec 05, 2016 9:20 am
CosmosK wrote:but if you merge them, how can you ensure the full depth pass goes last not first?
Because the merges respects the toolpath order.
Postby CosmosK » Mon Dec 05, 2016 3:10 pm
I open the file I posted and this is what I see. Two sets of arrows. You don't get this?
CosmosK
Postby CosmosK » Mon Dec 05, 2016 3:11 pm
This has not been my experience, but I will try again.
CosmosK
Postby Adrian » Mon Dec 05, 2016 3:36 pm
CosmosK wrote:This has not been my experience, but I will try again.
Make sure you have "Merge by Part" checked when doing the merge.
Postby CosmosK » Mon Dec 05, 2016 4:22 pm
Ok, maybe that wasn't checked. I will try again.
CosmosK
Next
Return to VCarve - General
Users browsing this forum: No registered users and 26 guests
