Corian with Vcarving
Postby auga » Tue Jul 18, 2017 5:53 am
So I made my first attempt with some carving with vcarve tonight. When the final cut with a 1/8 ball nose it make some noticeable tooling marks in the sign which is a pocket (using from D&M mom's garden).
So what the best way to get these tooling marks out?
Do folks using corian to carve for this reason or do they more do v-carve letter and a outer pocket.
I like the look but think it was be very difficult to get the tooling marks sanded out of the corian.
Thanks in advance.
auga
Model of CNC Machine: TinyG - Homemade
Re: Corian with Vcarving
Postby Adrian » Tue Jul 18, 2017 7:14 am
What stepover did you have defined for the ball nose? Assuming the machine is properly aligned etc you need a stepover of about 8% for the best finish with a tool like that.
Postby auga » Tue Jul 18, 2017 8:06 am
I am using a 8% step over. Same I been using with hard woods with no issue. Only seen with this on the Corian.
auga
Postby Adrian » Tue Jul 18, 2017 8:46 am
What sort of marks are you seeing? All over the bottom or just at certain points?
Postby auga » Tue Jul 18, 2017 2:41 pm
I see the marks on the bottom part of the carving.
auga
Postby Leo » Tue Jul 18, 2017 2:54 pm
I don't know what your "tooling marks" look like, so it is difficult to determine what the cause is.
I think, very often that many machine operators are not aware of or how to "tram" the spindle to be "perpendicular" in two directions to the table top. This condition will cause tooling marks in the bottom face of a pocket and be very difficult to "sand out".
Not knowing your issue, I cannot be sure, but this is a common issue.
www.leosworkshop.com
Leo
Postby Xxray » Tue Jul 18, 2017 7:09 pm
Corian is among the best of materials for shaping, no reason at all it should be leaving marks.
Not any info given to diagnose, maybe for curiosities sake try the same thing in wood or mdf and see if anything changes.
[1st attempts at anything are well known to often leave alot to be desired]
Xxray
Postby auga » Tue Jul 18, 2017 11:50 pm
When I carve from Ash I don't get the marks.
I think I change to a new bit, maybe it becoming dull?
auga
Return to VCarve - General
Users browsing this forum: mark-s, mtylerfl and 25 guests
