Tiling Option
Tiling Option
I'm about to do my first tiling operation, with feed through in the Y direction, moving 2 feet at a time. I need to use three different bits, how do I do this? I would expect that for each tile, I would be able to use each of the bits, then make the move, then reuse the bits again. How does the software keep track of which tile I am machining?
- mike.davison
- Model of CNC Machine: CAMaster Stinger II with rotary
Re: Tiling Option
Take a look at the generated G code. If you have 3 tiles you'll have T1_filename, T2_filename and T3_filename. Each file will be a separate job so will support multiple tools if your machine supports too changes. Take a look at the generated files; you'll see.
Aligning the tiles is an interesting challenge. It's up to you how to do this. If precision is needed you can specify some tile overlap and create alignment holes for dowels/etc as it makes sense. If precision is not needed you can simply measure from a point on your table. I use both as it makes sense.
There are several good tutorials available on YouTube.
Re: Tiling Option
Found the files, thanks. Started running the first panel and ran out of time. I will look at the tutorials, thanks for the lead. I did start with a single dowel and a line scribed by the machine in the Y axis, so tomorrow we will see how the alignment does with that method.
Re: Tiling Option
Fred, once you start running a tiled program it is probably best if you complete the whole job before you shut the machine down for the day. Along with alignment of the tiles themselves, the machine has to maintain it's original XYZ zero starting point until the end of the process. If you can reset to the original starting points you may be able to complete the job successfully. Good luck...joe
