Hello,
I vcarve some board, including QR code.
Look at the attachment : the QR code on the left is just a mirrored copy of the right one.
I need to mirror: i engrave on the back of a plexiglas.
The left reversed one is scrambled when calculating the vcarve path.
Sebastien
bug in carving algo
- Model of CNC Machine: self build on Isel frame
bug in carving algo
- essai1vectric.crv
- (1.58 MiB) Downloaded 149 times
Re: bug in carving algo
It's just luck that the other one worked ok. You can't have overlapping or touching vectors in a VCarve toolpath or you will get unexpected results.
You will need to edit the image to remove the overlaps etc.
It seems to be quite a rough image, did you generate it by tracing? There are a few QR generators on the internet that will generate SVG files that can be imported directly into VCarve and are a lot cleaner.
Thanks for the hint, i will look for SVG generator
