Just remember that the higher you set the preview resolution the more time it will take to generate, if you are running a high end machine with plenty of memory & a good graphics card then it's not a problem, if you are running an older machine that is short on memory it can be like watching paint dryredneck1210 wrote:Wow, somehow I never saw that. Thanks.dealguy11 wrote:Preview quality is different from modeling resolution. On the menu bar click on "Toolpath", then on "Preview simulation quality". Choose a higher setting to get a smoother simulation. I keep mine set at the max.
Also what other settings you are using like the animation & the bit cutting
