Flat Bottom Engraving Bits
Postby slick999 » Sat May 06, 2017 11:25 pm
Does anyone have a good source for a flat bottom engraving bit?
Would like to purchase one based on the Stacked Text Template tutorial.
20 - 45 degree angle 1/4 shank with a 1 mm flat bottom.
Any help is appreciated.
slick999
Model of CNC Machine: Viper XZ
Re: Flat Bottom Engraving Bits
Postby martin54 » Sun May 07, 2017 10:50 am
Don't know if they have exactly what you are looking for but a lot of people on the forum have said that drillman is a good seller, being in the UK I have never actually used them myself. :lol: :lol:
http://stores.ebay.com/CARBIDE-PLUS?_tr ... 7675.l2563
Postby NormanAlbert » Sun May 07, 2017 1:08 pm
Hi: Go to www.2Linc.com lots of different bits. Good people to deal with. Norm
NormanAlbert
Postby scottp55 » Sun May 07, 2017 1:55 pm
Martin,
I checked out the tutorial, and James specified a .03 inch flat.
Drillman1's .25" shank tools I'm 99% sure are true VBits(just looked at his 30/60/90* under 10X loupe).
His .125" shanks I use all the time, and unless it's specified as a "Sharp" tip(.006"flat), they are a .012" flat.
(I personally don't recommend the 30* "Sharp" as the tips break on me, BUT JUST used his new 60* "Sharp" and it cut wonderfully)
In .25" shank I use Onsrud 37-** series engraving bits with the .005 and .01" flats and Love them.
Page 19;
http://www.onsrud.com/files/pdf/OC-12-ProductionCuttingToolCatalog.pdf
After trying several suppliers I found best price and shipping options at Ballew Saw and they have the .03" flat in a 30*;
https://ballewsaw.com/onsrud-37-27-single-flute-sc-engraving-tools.html
Which I think is what the OP wants?
I HIGHLY recommend Drillman1, but haven't ever seen a .03" flat.
I did do the the small Stacked Text business card holder shown in pics, with Drillman's .125"2F Downcut EM, and the .125" shank 30* standard .012"flat, and was quite happy with it, in both the Cherry proto, and the Sugar Maple final.
Hope any of this helps,
GMH
scottp55
Postby martin54 » Sun May 07, 2017 2:11 pm
Scott, I will make a note of that so I know when people ask in the future. I haven't ever looked at what he sells because he doesn't ship to the UK, I just know that he has been mentioned on the forum by people I would trust myself :lol: :lol:
Norman actually linked to another Company that has been mentioned quite a few times who I also know nothing about personally but who's name eluded me when I posted :lol:
Postby WaltS » Sun May 07, 2017 3:26 pm
I agree with drillman1 on ebay. I use the 30 and 45 "flat" bits all the time. I also agree with Scott on the 30* sharps breaking. I used one the other day and broke it almost right away. It was brand new.
WaltS
Model of CNC Machine: ShopBot 2418 - Spindle - ScottP Spoilbrd
Postby ZipperHead55 » Thu Jun 15, 2017 9:55 pm
I'm very glad I found this thread, as it helped me decide what bits I would purchase to create these style (stacked text) of signs, plus other fine engraving projects I had in my head. I didn't really think about using a flat-bottomed cutter before (I saw sign making v-groove bits, but their flat spot is 3/16", which is WAY too big for this purpose, and I hated the look of the grooves after using a standard v-groove (60 or 90 degree) bit and I spent too much time/effort cleaning up around the lettering.
I decided to go with the Amana In-Groove line of insert cutter/blades: (link).
It is VERY hard to find these things in Canada, and while I was at the ToolsToday website, I got an offer I couldn't refuse: free shipping to Canada (which is fairly rare in my experience) and 10% off the total order (first time Canadian customer).
The price of the replacement blades is a little steep (~$22 each), but I figured that in the long run, it will be cheaper than buying individual bits. I bought the 8 piece set (the shank body plus a number of different blades) with a few extra blades in the size recommended by other posters above (60 degree, .03 inch tip width). I can imagine these blades will be even more fragile than the bits mentioned in threads above, so I will have to be VERY careful when using my touchplate and making sure I don't bite off more than they can chew (feedrate and/or pass depth).
I just ordered them, so I can't speak as to their quality/performance, but I thought it might help others decide on the correct tool for the job at hand.
Allan
ZipperHead55
Model of CNC Machine: Axiom AR4Pro+ and AR8Pro+
Postby Fleming » Fri Jun 16, 2017 1:10 am
Allen,
I have been using the In-Groove V-bits for a number of years now. They are very long lasting. I have not had a problem with the sharp points breaking but they do tend to round off through wear which is understandable. Those that do that I use for V-Carving larger text as the sides are still sharp. I only put in a new bit with a sharp point when I need to do fine or tiny text.
Paul
Fleming
Postby vgraves » Fri Jun 16, 2017 5:17 pm
I bought a set from PreciseBits and like them.
http://www.precisebits.com/products/carbidebits/2500_scoreengrave.asp?tsPT=!!!2Flute_Sign_Engraving!!!2Flute_Chamfering_SET!!!#Tabs.
Mine have a 0.029 diameter tip, and it looks like those have been replaced with a 0.015 diameter tip.
Van
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
Postby ZipperHead55 » Fri Jun 16, 2017 5:44 pm
Fleming wrote:Allen,
Paul
Thanks for the information. I was wondering about sharpening these blades, but I imagine it wouldn't be a good idea since it would likely throw off the balance and the cutting geometry (the flat size) would get effected. The headache and wasted material would likely be more than the cost of a new cutting blade. That's something I've learned the hard way, and made spending the amount of money I did on a good set that much more palatable (hopefully my wife understands.....). Now I just need to find the most cost effective place to buy replacement blades...
Allan
ZipperHead55
Postby Lesa Duncan » Wed Nov 13, 2019 3:59 pm
slick999 wrote:Does anyone have a good source for a flat bottom engraving bit?
Slick did you find a good bit for this I am working on it and that second layer is taking days to do? Did yours take days? Did you find a good bit for it? I am using a pointed bit and thinking maybe that is what the problem is?
Lesa Duncan
Model of CNC Machine: AR8 PRO
Postby gordread » Wed Nov 13, 2019 9:42 pm
I've been using the in-groove bits for years as well. I wouldn't trade them. They are very strong, and last forever. I almost exclusively use the 30' 0.005" flat and use a touch probe to set my Z on every job. I've never had one break a tip on me.
They are expensive to get in Canada ($33 each + shipping from toolstoday.com) but I haven't found anywhere else that is cheaper. I've tried other bits (precisebits.com) and a few cheaper box store/CMT, etc and they just don't go the distance, and they aren't that much cheaper than the in-line blades.
Gordon
gordread
Model of CNC Machine: CNC Professor HDX
Postby AlbertaClipper » Thu Nov 14, 2019 4:39 am
AlbertaClipper
Model of CNC Machine: Home Built
Users browsing this forum: brucem26, dealguy11, Ollie and 34 guests
