Help contents
hbhbbb
Help contents
Post by hbhbbb »
When I click on the "Help Contents" menu nothing happens.
Any help as to whats up would be appreciated.
Tony Mac
Vectric Alumni
Post by Tony Mac »
Hello,
Are you running the Full or Trial version of VCarve Wizard?
Pressing the F1 function key should also open the Help File in an Iinternet EXplorer Window - Does this happen?
Are you running Internet Explorer or another Web Browser?
Open a web browser window and Copy > Paste the links below open the Help file,
Full version - C:\Program Files\VCarve Wizard 2.0\Help\Index.htm
Trial version - C:\Program Files\VCarve Wizard Trial 2.0\Help\Index.htm
Does this open the Help File?
Sorry for all the questions,
Tony
Lrob
Post by Lrob »
Hi Tony,
Yes, I am running the full version. I took your advise and got the help menu to open when I opened IE before pushing the F1 key. It seems to only work with IE open first.
However, I am still confused as to how I would to a search for a particular subject on the help file. In this case I wanted to find out if I can hide a certain portion of my graphic as it overplaps with another.
Larry
Tony Mac
Vectric Alumni
Post by Tony Mac »
Hi Larry,
There isn't a search option in the Help file, but you can use the Find tool to search for a specific word.
With the Help File open select from the main menu along the top of the window,
Edit > Find (on this page) or press Ctrl +F
Enter the word to search for.
For your example of how to work with overlapping vectors try using the Weld tools.
I hope this helps,
Tony
