toolpath list reordering on its own
- Zcases
whenever I recalculate toolpaths, the toolpath list gets reordered. Is there a way to prevent this? I want to preserve the order I prescribe.....
thanks again
Scott
thanks again
Scott
- Gnarly Gnu
- Model of CNC Machine: ShopBot Desktop
Re: toolpath list reordering on its own
The issue here is for poor slobs like me that don't have auto tool changers. Here's the scenario: Create a drawing that cuts several pockets using a 90 degree v-bit with a 1/4" clearing bit and get a toolpath list something like:
Yin Pocket [Clear]
Yin Pocket
Yin Eye Pocket [Clear]
Yin Eye Pocket
Yang Inlay [Clear]
Yang Inlay
If I run this tool path in the order given, I'll change bits between my V-bit and my 1/4 downcut bit 5 times. If I manually change the order to:
Yin Pocket [Clear]
Yang Inlay [Clear]
Yin Pocket
Yin Eye Pocket
Yang Inlay
I only have to change the bit once.
This is a nice feature until I change any parameter of any of the tool paths and press either "Calculate" on the specific tool path, or worse yet, "Recalculate All Toolpaths", as it will reset the order to the original order shown at the top of this post. For this example, it's not too terrible. For the real 20+ toolpath combination I have for the project, it's a pain in the neck, and one that I've forgotten often enough to get stuck changing bits all day in the shop, much to the bemusement of my co-worker as he refers to me as "that outta control bit-changing fool"
Please show me the magical "Don't Change The Order Of My ToolPaths Once I've Set Them" option
-- or the "Oh here's the link to upgrade to 7.6 that includes that feature"
(BTW, VCarve Pro is #$@#!%ing fantastic -- it lets me do stuff I only dreamed of -- and more)
Yin Pocket [Clear]
Yin Pocket
Yin Eye Pocket
Yang Inlay [Clear]
Yang Inlay
Yin Pocket [Clear]
Yang Inlay [Clear]
Yin Pocket
Yin Eye Pocket
Yang Inlay
Presumably you're using manual tool change routines if you're saving all the tools to one file?
If you create two files (one for each tool) you could use the checkboxes (visibility) to control which toolpaths get put into each file.
The Clear and Pocket toolpaths are a special case in that they are logically one toolpath given the way they are edited. The software doesn't reorder other toolpaths.
- Model of CNC Machine: Home made
Dave....don't know if I'm on the same page as you, but in the toolpath list in lower right side, left mouse down on toolpath you wish to move and simply drag it to the order you wish. HTH....Herb
- BrianM
- Vectric Staff
You've added to a post from over 6 years ago, we believe this was fixed in later versions so if you are still having problems with a current version could you send the file to support@vectric.com so we can take a look?
Brian
Brian
It still does it on the latest versions. Create a couple of pocket toolpaths with the clearance option set. Move the Clear ones next to each other and click recalculate. The order is changed back to the default.
File sent to support -- thx, DaveBrianM wrote:Hi,
Brian
Thank you Herb, that is a nice trick -- much more efficient than select and click on the arrows like I've been doing all this time!!!HerbE wrote:Dave....don't know if I'm on the same page as you, but in the toolpath list in lower right side, left mouse down on toolpath you wish to move and simply drag it to the order you wish. HTH....Herb
(I'd still love to hear that they've made a change so that I can specify "leave my order alone you capricious tyrants!" )
Hello all,
This is an old topic, but it has apparently never been addressed. I'm having the same issue as CNCDave and Vectric never responded after he sent his file to Brian M (at least not in this post). Recalculating a toolpath changes the toolpath run order by placing the clearing and final passes back to back again. Is there a fix for this? I'm running the latest version of Vcarve Pro (ver 8.517).
Thanks!
Hispeed
Thanks!
Hispeed
