Is it possible to edit text without resetting the angle of the text to 0 degree?
If I have some text which has been rotated to say 30 degrees and then I go in and edit the height of that text via the text button it resets the text angle back to 0 and I must rotate it to 30 degrees again. Is there a work around or another method so I don't need to do this?
Editing Rotated text
- Thkoutsidthebox
