How about a good tutorial for creating drawings in VCarve. To try and figure out something from all the video on how to make the items represented is a tremendous waste of time. Getting the basics of creating the drawing and nomenclature down would be very helpful.
Having come from the world of mechanical drawing into CAD/CAM is a whole new step for many of us. A good example is how do you draw a square and then seperate the lines that need to be machined with a different tool. IE. 45 Vgrove for the sides. straight profile for the bottom and curve the top of the square in 1/2" at the center and put a 60 degree cut on it.
I have looked at most of the "tutorials " and have not found one that give me any idea of how to do something like this.
Seems like a great tool just need some guidance in how to create with it..
VCarve Tutorial
- IslaWW
Re: VCarve Tutorial
You might want to start with the Vectric Widget and then look at the Node Editing Tips and Tricks here: http://support.vectric.com/tips-and-tricks/select.php
GCnC Control
GCnC Control
Re: VCarve Tutorial
As a veteran Manufacturing Engineer I am also an old CAD guy, and also a board designer/drafter. Started with CAD in 1987 and used a whole bunch of that stuff through the years. I have been AutoCAD, CadKEY, Unigraphics, ProE, Mechanical Desktop, and Solidworks. Been through as many CAM systems.
I will agree, Vectric is not a mechanical package and it is more artistically based. I have been using Vectric since 2007 and there is a definite learning curve to it. It is powerful in that it is vector based and uses node editing, which I am now actually liking.
Because it IS an artsy program and not mechanical - there is a different mindset to it. That takes a little getting used to.
Sometimes I prefer Vectric over Solidworks. Vectric is just downright better for certain things than Solidworks is.
Vectric does take a bit of a different approach in the training tutorials, but I can assure you - NOT - useless.
They take an approach to do projects and use the icons and commands in demonstration.
In a mechanical CAD tutorial the training may be a bit more focused on - "Now this is how the line function works". Vectric does not do it that way. But then again Artsy drawing does not care as much about Vector length and direction. We get used to seeing that stuff.
I would recommend a bit of patience and go through the basic tutorials. They are actually very good, but you need to study and do the project, rather than just watch the video like a movie. There will still be questions, but post those questions here in the forum. There are some VERY talented people here that can help. Remember, we are not Vectric Staff - just users like you. Of course Vectric Support is also there for the help.
- FixitMike
Re: VCarve Tutorial
A good source of information if you need specific information about how a tool or toolpath works is the Help document. Just click on Help, Help Contents.
