Hello,
I have a question concerning the simulation/preview. Mostly I rather have the problem that the simulation/preview is way to fast on my computer.
On some files again the simulation/preview is very slow...Once started and then dont want to wait until it is finished, is there any way to stop it?
The only way I have found, is to close down V-Carve. Guess that is not really the best way.
Hope you understand what I mean.
Regards from Germany
Roy
Stop Simulation
When you run a simulation, you will notice a bar at the bottom of VCarve window (with 'slider' moving as simulation goes on).
At the right side, there is a small red X button. Press it to stop the simulation.
EDIT: This button also shows up when you're calculating toolpaths. You can also use it to cancel toolpath calculation.
- stop_vcarve_simulation.jpg (1.34 KiB) Viewed 2051 times
- Model of CNC Machine: shobot 48x96
