New Drag Knife
Re: New Drag Knife
Think it is pre installed Mark, open the software & check in the gadgets drop down
- Model of CNC Machine: multiple
Re: New Drag Knife
Since some people are asking for it and after some thought, I'm going to expand the design to add a couple offsets.
I’m going to offer the following models:
1.5mm offset, 1/4" shank (new)
3.0mm offset, 1/4" or 3/8” shank (current)
4.5mm offset, 3/8” shank (new)
I’m going to reschedule some stuff and try to have these ready by the first week of January. Send me an email (info@cosmos-industrial.com) if you're interested and I'll throw in a Holiday coupon code for a discount.
Pen Marking Tools from www.cosmos-industrial.com also>> CNC Drag Knife is back!
- Model of CNC Machine: ShopSabre408PRO-10HPHSD-10posATC-WinCNC
Re: New Drag Knife
martin54 wrote:Think it is pre installed Mark, open the software & check in the gadgets drop down
Well isnt that just ridiculous . I looked everywhere but the most obvious. Im not sure I should be playing with sharp things. Thanks
Re: New Drag Knife
How did you stop the motor rotation with with Vectric or Aspire? I don't see that anywhere to stop the spindle? Thx!
- Model of CNC Machine: ELU860
Re: New Drag Knife
website says that this item has been discontinued?
but no replacement part is available on the website.
what went wrong with it? ....I've been thinking about investing in a drag knife for a little while.
does anyone have any recommendations please?
- Mark
- Vectric Staff
Re: New Drag Knife
Hello bwohn65,
that start the spindle.
Cheers,
Mark.
Usually you would need to edit a custom post processor to remove any instructions in the header of the post processorbwohn65 wrote:How did you stop the motor rotation with with Vectric or Aspire? I don't see that anywhere to stop the spindle? Thx!
Cheers,
Mark.
Re: New Drag Knife
I discontinued the product as I got busy with other stuff and it's fairly difficult to make. There should be a couple other options out there. Thanks
- Model of CNC Machine: 3252
Re: New Drag Knife
What is the max cut depth of this? is it only restricted by blade offset
Re: New Drag Knife
Yes, it is the same as the blade offset. I'm working on bringing these back online. I will update when they are back in stock. Thanks
Re: New Drag Knife
Back in stock after 2.5 years!
The new model features a 7075 AL body (previously 6061). This is good for durability and thread strength. It is gray anodized as well.
Three models to choose from.
https://cosmos-industrial.com/index.php ... ex&cPath=4
Thanks!
Thanks!
- ChrisInEstes
- Model of CNC Machine: Vytek 4' X 8' - Perske Spindle - Mach3
Re: New Drag Knife
Good to know!
Chris
Chris
Re: New Drag Knife
Got a new one out:
Adjustable Offset Drag Knife
Adjustable Offset: 2-12mm (~1/16 - 1/2”)
Blades: Any standard sized utility blade. This lets you use HSS, Tin coated or Carbide edged blades.
Set screw is used to recall offset position between blade changes.
Body: Gray anodized 7075 Aluminum (high strength). 62.3mm long (not including blade stick out)
Bearings: Dual 7/8” diameter ball bearings offer best balance between radial load capacity and minimal overall length
Shank: Hardened steel 3/8”. 36.2mm length.
Clamp: 303 stainless steel. M5 bolt
Made in Fort Worth, TX
Days to ship: 1-2 (usually same day)
