Thank youscottp55 wrote:Has to be imported in the modeling tab.
Looking to learn:
- Model of CNC Machine: Shark HD4 Extended
Re: Looking to learn:
Thank you for this. I have just started watching the tutorials.martin54 wrote:As Scott says you have to import STL models not open them, have a look at this tutorial for a proper explanation
http://support.vectric.com/tutorials/V8 ... D_GEN.html
- Ms Wolffie
Scott
I just cannot get your website to work.
I get the front page but the tabs refuse to let me in
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Just want to thank all that responded to my post, everything you folks told me has been a great help, and I'm starting to get a picture of how things work in the 3D world. A lot to still understand, but on my way.
- scottp55
Off topic to Wolffie;
Just noticed that Tuesday Wolffie and told Kelly(salesperson/photographer/keeper of the web:)
We did have Northern Desktop in Limestone, but it didn't work out, so I have 2 machines in the house I'm upgrading.
New operator is 50 miles South so Kelly is trying to edit all the web stuff and it's not quite completed as little ones keep being born in the hospital and need their pics taken:)
Try right clicking and opening in a new window..seems to work for the moment. Think the 30 neck warmers are all gone now:)
Be well,
Sorry for 'Jacking:(
Be well,
R.N.
R.N.
- Ms Wolffie
Thanks Scott
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: BF-30 mill and 360 x 100 lathe
Lockwood, if you really want to recreate this image then aspire isn't going to help you; but you do need a proper 3d modelling/cad program (I personally use the fish one)
As has been said, you need to get this to an STL file.
1. With Vcarve trace the bitmap.
2. Clean up the vectors as best you can and get the basic shapes, features and outline in place
3. Export it as a DFX
4. With your cad/modeling software extrude the vectors and create a 3d mesh model
5. Shape the mesh up and bring your face to life. Copy the pic and get as much detail in as you can.
6. At this point I would also convert to a solid and get the vectors back for 2d cleanup (but you can skip this)
7. Once happy, save your mesh as an STL and import it back into Vcarve where you can machine it.
Good luck!
Good luck!
Sorry to say, but that's absolutely false.FastFarmer wrote:Lockwood, if you really want to recreate this image then aspire isn't going to help you; but you do need a proper 3d modelling/cad program (I personally use the fish one)
You may prefer another way of doing it, but Aspire is way more suitable for bas-relief 3D than most modelers, as many experienced and skilled Aspire users already proved it here.
As we have no artistic bone, we mostly use Aspire for 2D work, carving work and very simple bas-relief modeling. For actual 3D work, we use several high-end CAD software, so we know both.
Of course, if you already master an artistic 3D modeler, you may find easier to use it rather than learning Aspire, and it's a perfectly respectable opinion.
But you can't say that Aspire won't help.
PS: I'm in no way affiliated with Vectric.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Fair call. Good to see someone keeping me honest. I don't own or use Aspire so I shouldn't judge a book by it's cover.
I retract the comment Aspire won't help. Cheers
So you won't be hung at the end of the day by some Aspire fanaticsFastFarmer wrote:I retract the comment Aspire won't help. Cheers
If you're interested, download the demo which is 100% functional (except for generating machine code) and try modeling a bas-relief from the tutorials.
At the opposite, using Aspire to model actual 3D work doesn't make sense for me, except as a workaround for people not having or not willing to learn another tool for a punctual case.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
I have downloaded the Aspire trial and I am going trough the tutorials. I get bits of time to do this but things are kinda making some sense. I have a ways to go but for the moment research is the way to go. Also someone else informed me that the birdhouse face is a copyright pic, so I wouldn't use this one. I am finding things that are comparable on line and in a couple wood carving books I have. But I see 3d in my future. I did get the stl file opened and will be studying that a bit more.
Thanks for the feedback, John
Well, this is a lesson in being a smarty pants. I had a look and it supports "Create Shapes from Vector Outlines" so thanks to you I narrowly avoided the rope!! This feature would make this process very easy. CheersLittleGreyMan wrote:So you won't be hung at the end of the day by some Aspire fanaticsFastFarmer wrote:I retract the comment Aspire won't help. Cheers
- Model of CNC Machine: Piranha LX
Does vCarve Desktop v9 support "Create Shapes from Vector Outlines"
Thx
Thx
- mezalick
creativescrollworks wrote:Does vCarve Desktop v9 support "Create Shapes from Vector Outlines"
Thx
It does not..
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- sharkcutup
Here is one similar which I have worked into VCarve 8.5 and carved on my machine. It is a cat face for a bird house.
I just carved 3/4" premium pine by cutting down .125 & .250 on various items. Such as the nose first then carved the cheeks below the nose for the whiskers along with the eyelids, then carved the mouth area and eye sockets along with the eyebrows. Then cut the whole area out. Several Toolpaths along with time and patience and this is what I was able to achieve!
Keep Those Chips a Flying!!!
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
