ColourRout material in the USA
Postby dman » Thu Apr 20, 2006 5:53 am
Does anyone know where to purchase ColourRout type material in the USA? I am looking for a wood veneer with black base material. Does it exist is the USA?
dman
Postby RoutnAbout » Thu Apr 20, 2006 7:26 am
Dman,
This same question has been asked over on the shopbot forum, I forget where abouts but if I remember correctly there is a place in florida that has something very simular to ColourRout. There is supposed to be a place in the chicago area also.
Both dighsx (Jay) and I ran across a site that mentioned colored MDF by a place in Upstate NY. The information that both Jay and I posted is at the following thread link http://vectric.com/forum/viewtopic.php?t=176&highlight= I think its at the bottom of that page.
Just got home from work( 2am ) and after getting some rest, I'll see if I can find that information over on shopbots forum.
Don
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby dman » Thu Apr 20, 2006 5:50 pm
Thanks for the info Don. I would very much like to try a material like ColourRout for the PhotoVcarve pictures as well as any other signs/carvings.
dman
Postby Burchtree » Wed May 03, 2006 12:45 am
One option for ColourRout is to make your own and add even more of a personal touch to your work. You can find good veneering information at. http://www.joewoodworker.com/
Dan
wood signs
(73.03 KiB) Downloaded 358 times
(22 KiB) Downloaded 787 times
Burchtree
Postby Scott » Sat May 06, 2006 4:48 am
Any of the veneered MDF's work well. Cherry, birch, and oak. After routing and sanding them, stain them. The stain will wipe off the veneer and be lighter with the MDF soaking up the stain and being much darker providing a nice contrast. The finer you sand the veneer the less it will stain.
Here's one that was done with cherry veneer MDF.
(195.78 KiB) Downloaded 405 times
Scott
Scott
Model of CNC Machine: ShopBot PRS Alpha
Postby CRFultz » Sat May 06, 2006 10:50 am
Scott,
Thats a really nice piece of work. Can you share with us the tool you used? The lettering
is clear and crisp. Maybe the depth of cut as well...
Thanks..
Chuck
CRFultz
Postby mcurtis » Sat May 06, 2006 12:21 pm
And the material supplier? (or did you laminate it yourself?)
Looks Great!
Maynard
mcurtis
Postby Scott » Sun May 07, 2006 6:21 pm
Thanks. The beveled edge and the border was cut with a 90 degree bit and the text and accents were done with a 60 degree bit. The size of the plaque is 21.5" wide by 38" long. Max depth on the text is 0.0911" The font is called "BlacklightD". This font works really nice for text as it cuts clean and deep enough to make it clear and crisp. This plaque was first sprayed with two coats of conversion varnish, cut, and lightly sprayed with a dark brown fast drying spray paint in the carving and the edge (I applied a little mask first). Then after the paint was dry, the overspray was sanded off and then two more coats of conversion varnish were applied. Sounds like a lot of fuss, but it's really not that bad. Staining veneered MDF plaques after cutting and then finishing is much quicker/easier, but I wanted the cherry to be natural and age to its nice warm color.
If I don't need a higher grade of veneer on the MDF, I can get oak and birch locally at Menards (this often requires digging to the bottom of the stack at 90lbs/sheet). The cherry MDF and a few others, I can get from my lumber/plywood supplier Friendship Hardwoods in Frienship, WI.
Here's a couple of mirrors done in oak and birch MDF with stain.
(107.7 KiB) Downloaded 379 times
(74.8 KiB) Downloaded 336 times
Scott
Scott
Postby Scott » Sun May 07, 2006 6:35 pm
The oak one.
(110.35 KiB) Downloaded 343 times
(127.7 KiB) Downloaded 330 times
Scott
Scott
Postby CRFultz » Mon May 08, 2006 1:36 am
Thanks for the info Scott, nice work on the mirrors...
Chuck
CRFultz
Postby dman » Mon May 08, 2006 2:48 am
Thanks for all the replies. I have to give laminating a try. Has anyone tried this with photovcarve? It seems to be the way to go for wooden pictures if it works like the above examples.
dman
Postby Burchtree » Sun May 14, 2006 12:13 am
Hi all
Here is a picture V carved into curly maple that I veneered on to cherry.Size is 7x7 inch Bit 60 degree 170% line spacing .050 deep
Dan
Curly maple on cherry
(16.06 KiB) Downloaded 816 times
Burchtree
Users browsing this forum: doncraig, sharkcutup and 17 guests
