Just to help those with a similar issue, to fix this issue I went ahead and completely uninstalled VCarve, then used CCleaner to clean the registry and then rebooted. I then used my search program to check the entire PC for any remnants of Vectric software and manually deleted them. I then reinstalled VCarve and I must not have eliminated everything because my license info was still intact, BUT.....my thumbnails DID return and all is well!
Hope that helps!
Problem with thumbnails
- fretsman68
Re: Problem with thumbnails
Dave
Dave
Is that with the cloud sync turned off on those folders?
- fretsman68
No sir, everything is syncing as normal!Adrian wrote:Is that with the cloud sync turned off on those folders?
Dave
Dave
- fretsman68
Here's how it's always looked for me:
- Capture.JPG (10.83 KiB) Viewed 1026 times
Dave
Dave
Are the thumbnails updating when you change the files? I've been able to rebuild the thumbnails in the past but they don't stay in sync with the changes to the files unless I move them to a non cloud sync location.
- fretsman68
Hi Adrian,Adrian wrote:Are the thumbnails updating when you change the files? I've been able to rebuild the thumbnails in the past but they don't stay in sync with the changes to the files unless I move them to a non cloud sync location.
I just did a test for you and yes, they update immediately.
The 2 images below: "Capture1" the file vectors were saved to a pink color. "Capture2" I saved it to black colored vectors and it saved immediately as I could just close the file, then re-open that same file. I never ran into an issue when saving my sync'd files.
Dave
Dave
