Peck drill will not turn off
Jeff E.
Post by Jeff E. »
Running a very simple job and can't get peck drilling to shut off. Outputs the same gcode checked or unchecked - suggestions? crv attatched.
Regards,
Jeff E.
mote.crv
(45 KiB) Downloaded 159 times
Tony Mac
Vectric Alumni
Post by Tony Mac »
Hi Jeff,
You have the Pass Depth for the Drill / Cutter set to 0.025 which limits the
toolpath to have a maximum cut depth / peck of 0.025", resulting in 3 passes
Edit the Pass Depth = 0.075" or greater and the holes will be drilled in a
single pass.
hope this helps,
Tony
