help with tool setup
r3llc
Post by r3llc »
I purchased the Amana in-groove system and I would be very appreciative is someone could help me properly setup one of the bits.
I am going to use RC-360 Engraving bit (30 degree) as an example. here are the specs from the amana website.
Tip: .005
tool depth: 5/8
here is a picture of the bit
I assume I would set this up as an engraving bit so what im asking is what values should I user for Diameter, Side anle, and Flat Diameter ?
tmerrill
Model of CNC Machine: ShopBot
Re: help with tool setup
Post by tmerrill »
I don't own these but posted this guidance a while ago. Didn't get any bad feedback so assume all went well.
See this thread:
http://www.vectric.com/forum/viewtopic.php?f=27&t=12708
For the diameter, try to measure and determine the diameter at the top of the angled cutting edge.
Tim
Ms Wolffie
Post by Ms Wolffie »
I followed your instructions for mine, it worked out well.
I printed them out and use them as reference.
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
BDM
Post by BDM »
Wolffie wrote:I followed your instructions for mine, it worked out well.
Cheers
Wolffie
Not exactly, your side angle for a 30 degree v bit should be 15 degrees not 30.
Ms Wolffie
Cheers
Wolffie
:oops:
Wolffie
Cheers
Wolffie
Whatshammacallit
