VCarve Pro - Making a single straight line
Postby jimreed1948 » Fri Feb 22, 2013 10:25 pm
I'm new to Vcarve Pro but not to drawing software. Two other programs I have used have a tool to draw a straight line, Vcarve doesn't. What's the trick here? If I use another tool such as the arc, and use it for a straight line and not an arc, it looks good, but it will not cut because there is an open vector.
So how do I draw and cut a single or multiple straight lines?
Thanks for the help.
jimreed1948
Model of CNC Machine: Torchmate
Re: VCarve Pro - Making a single straight line
Postby tmerrill » Fri Feb 22, 2013 10:28 pm
Use the 'Draw Polyline' tool. Realize a single vector will be an open vector, whether straight or curved. There are toolpaths that work with open vectors and those that don't. It really depends on the results you are trying to get.
Being new to the software, are you aware of the tutorials found here - they can really help get you going:
http://www.vectric.com/support/training-material.html
Tim
tmerrill
Model of CNC Machine: ShopBot
Postby jimreed1948 » Fri Feb 22, 2013 11:08 pm
tmerrill wrote:Use the 'Draw Polyline' tool. Realize a single vector will be an open vector, whether straight or curved. There are toolpaths that work with open vectors and those that don't. It really depends on the results you are trying to get.
Tim
Thanks for the help. I have reviewed some of the video but not the one that showed the polyline tool. I can now draw a straight line. I also found the toolpath you were talking about and it works fine now.
jimreed1948
Users browsing this forum: Bing [Bot], gkas, Paul Stewart and 18 guests
