Program to generate wavy panels
PaulRowntree
Post by PaulRowntree »
Greetings All;
Over the past year I have been working on a program to create wavy panels for cutting on my cnc. The textures that interested me were like the ripples of sand underwater at the beach. These textures can be wrapped, laid on flat, or even Warped. On the off-chance that someone else could also use this program, for fun or for profit, Standing Waves is available for free download from PaulRowntree.weebly.com
The program works by generating 2 or 3 EPS files of overlapping 'sausages', extending out along X. You can adjust the parameters that control the shapes and randomness of these sausages. You can preview these sausage files on screen without going through VCP. Then load up the 2 or 3 EPS files into VCP or Aspire, V-Carve them with a ball-nosed bit (1" works well), and you are away. The panels can be any size, and they are periodic in X and Y so they can make larger murals if you want. The patterns can be controlled, and you can exactly recreate any panel in the future by keying in some parameters (that are also saved to disk for you when you create the EPS files). Any number of similar, but different, panels can be created with a click.
The download zip file has the executable, a manual and some sample files to get started.
Cheers!
boardtest.crv
(2.78 MiB) Downloaded 566 times
Paul Rowntree
andyb
Model of CNC Machine: MultiCAM, Shopbot PRTAlpha
Re: Program to generate wavy panels
Post by andyb »
Thanks. I will have to try it out.
Andy B.
[b]Oak Branch Manufacturing[/b]
andy@oakbranchmfg.com
678-971-5502
[url]http://www.oakbranchmfg.com[/url]
Ms Wolffie
Post by Ms Wolffie »
That is neat.
Thank you.
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
velvetpig
Model of CNC Machine: DIY
Post by velvetpig »
Thank you, This will be fun.
Bob_S
Model of CNC Machine: Shopbot desktop Max
Post by Bob_S »
I will certainly give that a try to produce some background textures
Even though you are on the right track - you will get run over if you just sit there.
Will Rogers
zeeway
Post by zeeway »
Thanks, Paul. A while back I had tried to model waves, but yours looks much better.
Angie
GaryR6
Post by GaryR6 »
Thanks, my first attempt looked more like an earthquake...... will try yours.
WoodEraser
Model of CNC Machine: Shark Pro Plus
Post by WoodEraser »
Thank You Paul.
I will give this a try.
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
kzeyus
Post by kzeyus »
Thanks Paul!
Will give it try when things slow down.
Ken Zey
Rogers, AR
http://www.CedarSlabSigns.com
http://www.lookoutmercantile.com
Shopbot PRS Alpha 72x144
dond52
Post by dond52 »
Thank you Paul. It looks a great way to create different backgrounds.
Norb
Model of CNC Machine: MAXI-C 1530 SE-T-V
Post by Norb »
Thank you very much Paul, but is there any chance of an option for the metrically inclined?
Norbert
Aspire 4.x, PartMasterCAM Turn, Autocabinets
after hours: Sherline 2010 and 4410
ChrisInEstes
Post by ChrisInEstes »
Cool stuff. I'm going to give it a go.
Thanks!
Chris
PaulRowntree
Folks, I am delighted that you are trying it out! You are more than welcome. If you make something cool with it, please post it.
Norb wrote:Thank you very much Paul, but is there any chance of an option for the metrically inclined?
Norbert, my apologies. When I step into the garage, my mind stops working in metric. I will look into this. It shouldn't be too tough.
Cheers!
Paul Rowntree
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Post by jimwill2 »
Paul,
I just downloaded your new program and I can't wait to try it. The Paypal link never appeared... can you post the link? I couldn't find it on your website.
Thanks for the great work you do in your spare time, you appear keep pretty busy.
Jim Williams
PaulRowntree
jimwill2 wrote:Paul,
Hi Jim;
I have been a bit self-conscious about posting the PP link. I will be providing updated versions of WarpDriver and StandingWaves ''Real Soon Now'' (thanks Jerry Pournelle), and the link will be up then (always voluntary). So if you can think of changes or improvements, now is a good time to let me know.
Cheers!
Paul Rowntree
