Cut file problem
Cut file problem
Postby Phil » Tue Jan 31, 2006 6:26 pm
When I create a cut file Photo V-Carve inserts these commands at the beginning of the file
VD,,,1
VA,
MS,42.2,12.6
JZ,1.524000
J2,0.000000,0.000000
the VD command changes my display to MM even though I selected all inch settings when I created the file.
I am using a Shopbot - *.sbp files.
Phil
Postby BrianM » Tue Jan 31, 2006 7:07 pm
Hi Phil,
Are you sure you are selecting the
"ShopBot (inch ) (*.sbp)"
post processor from the list and not the "ShopBot (mm) (*.sbp)" post?
We have a fair number of users using PhotoVCarve on ShopBots in inches any we haven't had this problem reported before.
Brian
BrianM
Vectric Staff
Cut file problem
Postby Phil » Tue Jan 31, 2006 7:30 pm
You're right Tony, I figured out the problem 5 minutes after I posted the message. - thanks.
Phil
Users browsing this forum: No registered users and 26 guests
