How to just cut a single straight line
Postby KGunnett » Thu Jul 26, 2012 3:00 am
I'm pretty new to V-carve, I don't even have a CNC machine yet. I figured that it was better to learn something about the software before ruining a bunch of wood. I'm learning by watching the videos...
I just haven't figure out how to do this. I draw a square box. Inside that box, I place a large box, on top of that I place a smaller box, and another on that, sort of forming a set of stairs. I join or group the boxes together, then I remove all the interior lines. I then select the large square and stairs, and use the pocket toolpath to leave me a raised platform in the center of the work. Lets say that is machine down to a 1/2 inch.
Now, this is my probem, I would like to put back some of the lines I deleted, but only deep enough to make them show up (.005?). I select the line I want to engrave, and V-carve tells me it is a open vector.
How do you do it, all I want to do is engrave a straight line, and tell the program to center the bit on that line. I'm sure it is something simple.
And on the subject of open vector, is there a way to get V-carve to show me where they are located?
Thank you in advance...
K.G
KGunnett
Model of CNC Machine: General iCarver 40-915X M1
Re: How to just cut a single straight line
Postby Adrian » Thu Jul 26, 2012 7:15 am
To find the open vectors look on the Edit menu and you'll find an entry called "Select All Open Vectors".
For the toolpath you need to use a Profile toolpath rather than a VCarve toolpath. As you've found out a VCarve toolpath will only work on closed vectors.
Postby zeeway » Thu Jul 26, 2012 10:56 am
You will also find that in v-carving a single line, your selection of a shallow depth will show up as a line of varying width if the top of your material is out of parallel with the horizontal plane of the spindle. In other words, a selection of 5 thousandths for a depth may not show uniformly on your workpiece.
Angie
zeeway
Postby KGunnett » Fri Jul 27, 2012 1:37 am
Oh just great! I just did what you said, and now feel like a complete idiot! :) The profile toolpath was the only place I didn't look.
Thanks again....
K.G
Adrian wrote:To find the open vectors look on the Edit menu and you'll find an entry called "Select All Open Vectors".
KGunnett
Users browsing this forum: ger21, sylvan356 and 11 guests
