How to create a template for a clock dial
Postby RichardF » Tue May 08, 2012 10:47 pm
I'd like to vcarve a clock dial but have no success in placing the 12 numbers in 30 degrees steps correct.
I drew a circle and copied 12 lines around the center to have the correct angle but with the ' wrap text around a curve' tool I have no success.
Any ideas out there ?
Richard
RichardF
Re: How to create a template for a clock dial
Postby Bill_L » Wed May 09, 2012 1:02 am
Richard,
Make your first line the exact distance from the center to where you want your numbers placed. Then do your copy rotate. Next choose your font and create your numbers one at a time. Lastly, select your numbers and drag them to the end of each line and they will snap and stay at that position. Now you can delete all the lines and your numbers are in place.
I hope this is what you were after. If not, give us a little more information and we'll take another crack at it.
Bill
Bill_L
Postby RichardF » Wed May 09, 2012 12:39 pm
Bill,
thanks for that tip :D
Great result
Richard
Clock Dial
RichardF
Postby Lameiii » Wed May 09, 2012 2:15 pm
I really like your clock face. Would you mind sharing the file?
Jim
Lameiii
Model of CNC Machine: Romaxx WD1
Postby RichardF » Wed May 09, 2012 2:26 pm
No problem , Jim , here it is
Richard
ClockDial.zip
(664.48 KiB) Downloaded 272 times
RichardF
Postby GaryR6 » Wed May 09, 2012 4:21 pm
Thanks for the info and data.
Tic Toc tic toc
GaryR6
Postby RichardF » Sun Jun 10, 2012 12:54 pm
For those who like roman numerals
The font can be found here : http://www.iconian.com/a.html called achilles
Richard
AchillesRoman.crv
(844 KiB) Downloaded 127 times
RichardF
Users browsing this forum: Bing [Bot], gkas, Paul Stewart, TexasEagle and 22 guests
