Hello all,
I want to make an 3D cut with this foto. A very old (how do you call it) motorcycle. Is there a nice and easy way with vcarce to do this??
Thanks in advance
greets Juan
http://www.home.versatel.nl/crazydiver/Puch.jpg
Help with an 3d file
Re: Help with an 3d file
Hello Juan,juan wrote:Hello all,
Thanks in advance
greets Juan
A 3 dimensional object derived from a photo is not within the realm of VCarve Pro by itself.
It is however possible to cut a engraving from the photo using Photo VCarve.
The image you posted would have to be edited to remove the fold in the middle.
If you would like to produce a 2.5d flat engraving , I'm sure we can assist if needed.
Chuck
- Paco
Photo VCarve will etch or create a 3D relief (litho-like) based on the grey scale result of the picture.
If you want to have a 3D model of it, either full 3D or surface relief, it need to modeled in 3D CAD then toolpath in Cut 3D.
That's pretty much how far I can help based on what you provide as infos...
