Need help doing my first real sign.
I've got a sign which is approx. 2' x 3'. I'm using precision board. I'm using v-pocket follwed by a vbit. It only allows me to use two bits one for roughing and the vbit. Is there a way to be able to use more than one roughing tool (1/2,1/4,1/8) beofore the vbit? This would save a lot of time. Right now I'm using a 1/8 and a 60 deg. vbit. Also what should I be running these bits at (feed rate) in precision board? Thanks Brian
Yes, I'm using a 2 flute upspiral 1/4 end mill then a 2 flute 60 degree vbit. My total depth will be .250".
I'm running it on a shopbot (stepper motors) with a portcable router.
Should I still run it at the those feeds & speeds?
Thanks for the info. This is the first time I'm attempting to cut sign in presion board.
Thank you.
Brian
Thank you.
Brian
