Imperial and Metric conversions
Postby jt » Sun Jan 22, 2006 1:17 am
I just downloaded the demo version of VCarve. The first drawing I started was in mm. The next drawing I imported was an ACAD 2000 dxf file drawing inches. The material thicknes was .25" When the drawing opened it was reading mm so I changed the units to inches but when I went to do a 2D tool path the Toolpath Box was reading 25inches thick. What is the best way to open a drawing when you are using diffent units?
jt
Postby BrianM » Sun Jan 22, 2006 10:12 am
Hi jt,
The thickness is set on the same page you set the job dimensions when you open the file. You can also change it at any time from the Material Size form on the toolpath tab. The attached images should show this.
Regards
Brian
Setting material thickness when loading a file
(9.81 KiB) Downloaded 545 times
Changing material thickness after file has been loaded
(29.62 KiB) Downloaded 136 times
BrianM
Postby jt » Mon Jan 23, 2006 11:22 pm
Hi Brian
It seems like if I open a file say 1" and I click mm then the thickness is then 25.4mm. I click O.K. The toolpath box is updated but if I go to change the file back to inches the toolpath thickness doesn't get updated.
Sincerely
jt
Postby GP Guest » Tue Jan 24, 2006 1:21 am
Yes, I found the same issue but decided it doesn't really cause a problem as I always run in Inches. I guess the 'rest of the world' will cut in mm's and never imperial (?) so the problem goes away the first time you start a job - or have I missed something?
Great job guys!!
G.
GP Guest
Return to VCarve - General
Users browsing this forum: doncraig, Jan.vanderlinden, sharkcutup and 18 guests
