Bulls Head pattern
Bulls Head pattern
Postby tony » Wed Jan 18, 2006 4:56 pm
How does the program know to cut deeply around the "B" in Bullshead and then cut very shallow around the filligree? thanks, tony
tony
Postby Paco » Wed Jan 18, 2006 5:39 pm
V carving strategie's magic!... in short, it's all about the cutter shape; the deeper the wider... :wink:
I'll let Tony or Brian chime in if you need more detailed infos.
Paco
Postby Burchtree » Wed Jan 18, 2006 6:18 pm
Paco is right the width of the lines plus the degree of the V carving bit determine depth of the cut. If you had two lines .125 wide 60 deg. bit will cut deeper than a 90 deg. bit. Two lines .250 wide will cut deeper than two lines .125 wide with the same v bit.
I hope this helps
Dan
Burchtree
Postby Tony Mac » Thu Jan 19, 2006 12:16 am
Hi Tony,
Good question and the simple answer is the mathematics engine in VCW is pretty clever and automatically calculates a constantly changing 3D center-line between any combinations of vector boundaries. This algorithm is key to the VCarving process and takes care of even the most complicated of designs.
Imagine the letter ‘T’ with the cutting edges of a V-Bit cutter resting on the outer edges of the vertical lines. The tip of the cutter will automatically drop to the middle point inside the letter to a depth that depends upon the width of the letter and the angle of the cutter. Where, the tip of a pointed cutter such as a 60’ included angle will drop deeper than a 90’ included angle cutter.
Taking this a step further. Where the gap between vectors changes - gets wider or narrower, the depth of cut will also change and VCW calculates the constantly changing points to create a precise, flowing toolpath.
The math gets significantly harder for more complicated shapes and combinations of vectors.
The diagram below tries to show what I mean using an example where the gap between the vertical and horizontal regions is constant, but changes in the corners and also where the 2 bars meet.
Hope this makes sense?
Tony
Tony Mac
Vectric Alumni
Bulls Head
Postby tony » Thu Jan 19, 2006 5:01 am
It does make sense, thank you for the replies. tony
tony
Users browsing this forum: mtylerfl and 36 guests
