Always wants to cut flat bottom
I was trying to just carve a plain sign without the flat bottom feature and I un checked the box for flat carving but it still always wants to cut a flat bottom even with the v bit? is there a way to turn that off?
Re: Always wants to cut flat bottom
It sounds like you want to Profile cut with a v bittruman wrote:I was trying to just carve a plain sign without the flat bottom feature and I un checked the box for flat carving but it still always wants to cut a flat bottom even with the v bit? is there a way to turn that off?
A profile will cut on; inside; or outside.....It just depends upon what you are looking for.truman wrote:so you are saying that if I just want to cut the letters I would just choose profile? would that automatically adjust for line thickness and everything else?
If you wish to engrave the letters then a profile will be the right choice.
If you wish to cut the letters out then the same thing applys...but cut completely thru.
There are so many ways to skin a cat when it comes to VCarving....
V Carving is for enclosed regions......but profile cuts on the other hand...it doesn't matter...it will cut what you want.
Hope this helps ya out
Chuck
