So here's what you would think is a simple question, but its surprising how difficult it is to find basic run of the mill glitter!
Remember the 'Howling Wolf Inn' sign that someone did? (Great sign) Anyway...they used some sort of dark blue glitter on it. Basically I need that same glitter, and also a light blue version. I also need whatever type of clear drying glue was used to secure it in place on the sign.
Any help is much appreciated. Im intended to finish over it with clear gloss varnish, so the glue will have to be compatible....or maybe I can coat with something like shellac then varnish over that?
A glitter supplier online, and advice about the glue/finish combination is much appreciated. Thanks.
