Profile cut problem
Phil
Profile cut problem
Post by Phil »
I want to do a 3D Bevel Edge letter. I followed the "How To" on the web site and it works fine. However I'd like a thinner profile for the letter. If I machine with a 90 degree V bit "On" the vector I will get the thinner profile but I can't select the "Sharp outside or sharp inside corners" option. I can only select the "Sharp corners" option when machining inside or outside the vector. Is it supposed to work this way? Machining inside the vector makes a profile that is way too thin.
Paco
Post by Paco »
Offset inward by the amount you need. If you don't know, you'll need to make some tests.
"Currently", VCP offset the original vector(s) outside with some trig. based on the V bit angle and depth of cut for the cut out tool path... maybe we'll get more option in the future...?
Does that help?
Phil
Post by Phil »
Sounds like a workable plan, I'll give a shot.
Thanks Paco.
