Finding open and duplicate vectors
Postby ilsaarin » Fri Jan 07, 2011 2:41 pm
I finally desided to change the software from A**C** to VCarve pro. I have spent hours and hours editing bad vector pictures with it and yesterday I got enough. That expensive software don't have any tools for finding duplicate vectors or open vectors. It can be done if you know the tricks but it requires a lot of manual work. The fonts are exploding and they have to be node edited before I can machine anything. When I got fustrated after 2 hours of editing, I tested the same file with Aspire trial and the job was done in 10 minutes. Then I went to the Vectric homepage and now I am 450 euros poorer than yesterday. I should have purchased VCarve 3 years a go.
But now to the question:
Command "find duplicate vectors" won't find all of them. Does somebody know why? Also "find all open vectors" fails. I just used the command for finding open vectors and the result was that there isn't any in my design. But toolpathing had different opinion and refused to make a toolpath to one part because vectors were open.
Does anyone know the reason for this?
Ilkka
ilsaarin
Re: Finding open and duplicate vectors
Postby BrianM » Fri Jan 07, 2011 3:35 pm
ilsaarin wrote:...
Ilkka
Hi Ilkka,
The seelct duplicate vectors command will only find vectors which are pretty exact duplicates, these are often created by drawing packages when fills etc are applied and they can be very difficult to spot by eye.
The most common reason for not finding open vectors is that they are grouped together. The 'select open vectors command' only selects individual vectors. When the toolpaths are created the groups are broken down into individual vectors and this may be when the program is spottign the open ones. If your vectors are not grouped, perhaps you could post the file or send it to support at vectric so we can take a look.
Brian
Brian Moran
Managing Director
Vectric Ltd.
BrianM
Vectric Staff
Postby tmerrill » Fri Jan 07, 2011 3:37 pm
Edit: I see Brian has already answered but there may be a few additional tidbits here that may help.
Ilkka,
Congratulations on the purchase!
The ability to find open vectors and duplicate vectors has worked fine for me as long as nothing is grouped. If you have anything grouped, be sure to ungroup them first.
Sometimes it is hard to see them, especially the duplicate vectors. So after using one of the commands, it is best to immediately hit the delete key for the duplicate vectors and with Open vectors I normally use the new Copy to Layer command so I can take a look at them. Sometimes single pixels created unintentionally can give problems and be hard to find.
There are two other tips for open vectors. You can select all vectors and open the Join Vectors tool (shortcut is J). The box that opens for the Join Vectors tool will give you a summary of how many vectors are closed and how many are open.
You can also use the new Vector Selector feature to select all open vectors or just on a specific layer or layers.
If none of this helps, can you post the file that is giving you problems?
Tim
tmerrill
Model of CNC Machine: ShopBot
Postby gbanet » Fri Jan 07, 2011 5:08 pm
Draw a random line, anywhere. Select that line and the vectors that are open. Then under the "Edit Vectors" toolbar, select "Join vectors with a line". This will lead back to the problem.
Greg
gbanet
Postby esteeme1 » Fri Jan 07, 2011 5:14 pm
Greg that's a great tip.
gbanet wrote:Draw a random line, anywhere. Select that line and the vectors that are open. Then under the "Edit Vectors" toolbar, select "Join vectors with a line". This will lead back to the problem.
Greg
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Postby ilsaarin » Fri Jan 07, 2011 5:21 pm
Good tips, thank you both.
I sent a file to Vectric. Let's see what they find from it.
Ilkka
ilsaarin
Postby Mark » Fri Jan 07, 2011 7:01 pm
Hello Ilkka,
Thanks for sending in the file. It is not too much work to sort it out.
I have emailed it back to you.
I hope that this helps.
Cheers,
Mark.
Mark
Vectric Staff
Postby ilsaarin » Fri Jan 07, 2011 7:48 pm
:shock: :shock: It not even office time anymore!! Now it is time to relax and go to the pub and not to work!
Mail received and studied carefully. I managed to clear the picture before I asked the question. Now I know how to clean up those messy pictures much more efficiently. As said many times before: Excellent customer support. I will pay my Visa bill with smile on my face.
Ilkka
ilsaarin
Postby cac67 » Fri Jan 07, 2011 8:54 pm
Greg
This is one of those things that make me want to slap myself for not thinking of it myself. Great idea!
cac67
Model of CNC Machine: Joes Evo 3x2
Postby RoutnAbout » Sat Jan 08, 2011 1:34 am
Greg
Great Tip Greg,
I guess you still know your way around the keyboard... :twisted:
Don't forget about the information the status bar.
When vectors are slected the status bar will give you a total count of closed and opened vectors
In the photo there are 4 open vectors and 1 close with a total of 5 and noted in the status bar by S5 (I think the S is for selected)
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby ilsaarin » Tue Jan 11, 2011 7:02 pm
My opinion still is that this is not working properly. Take a look at the pictures. First Vcarve couldn't find any open vectors but then I switched layer visibility on and off. Then those small horizontal lines were found.
ilsaarin
Postby esteeme1 » Tue Jan 11, 2011 7:08 pm
The vectors need to be selected. In your example they are not.
Jim Darlas
"Can Do!"
esteeme1
Postby ilsaarin » Tue Jan 11, 2011 7:38 pm
No, they don't have to be selected before using the tool.
ilsaarin
Postby Mark » Wed Jan 12, 2011 10:30 am
Hello ilsaarin,
The select open vectors command will only work on layers that are visible.
If you are having problems with a particular file, why not post it up here and we will take a look at it.
Cheers,
Mark.
Mark
Vectric Staff
Postby BrianM » Wed Jan 12, 2011 10:32 am
Usually you will find that those vectors actually double back on themselves and are actually closed vectors. If you use the measure tool and select 'Span / Contour Properties' and then click on the apparently 'open' vectors it will give you more information about them at the bottom of the form including whether they are open.
Brian
Brian Moran
Managing Director
Vectric Ltd.
BrianM
Vectric Staff
Next
Users browsing this forum: No registered users and 21 guests
