engraving dilemma; Harley Davidson
Postby Mofosheee » Sat Apr 14, 2018 4:10 pm
I have a motorcycle engine side cover (Harley Davidson derby cover) with an allowable engraving area of 5.75" circular. Problem is that the elevation of the engraving are descends 0.2" from the high point in the center of the cover to the outer limits of the intended engraving area. Does anybody have a work around or suggestions to approaching this job? Thank you
Mofosheee
Re: engraving dilemma; Harley Davidson
Postby gkas » Sat Apr 14, 2018 6:11 pm
Draw a dome that matches the curve of the cover. Then project your engraving onto the 3D.
gkas
Model of CNC Machine: Axiom AR8 Pro+, Axiom 4.2W Laser
Postby FixitMike » Sat Apr 14, 2018 6:23 pm
If you use a spring loaded diamond drag tool, the spring compression may be enough to cover the change in elevation I have one with 3/8" compression. My experience with acrylic has been that the amount of compression makes very little difference in the lines. I don't know how well the aluminum cover will engrave with a diamond drag tool, however.
Best would be if you can find a scrap side cover to experiment with. Let us know what you end up with.
FixitMike
Postby cbr_speedster » Sun Apr 15, 2018 8:57 pm
If you want to send me your engraving I can model it for you..
cbr_speedster
Postby highpockets » Sun Apr 15, 2018 9:59 pm
You might check into G-Code Ripper http://www.scorchworks.com/Gcoderipper/gcoderipper.html
You can map the contour of the cover then engrave the image.
Postby Mofosheee » Mon Apr 16, 2018 1:49 pm
Thanks to all who replied. And to highpockets, you are the second person to have pointed me in this direction. I will certainly investigate.
I figured out how to do it with a competitors software then projecting the lines to the surface. But I want to do it using vectric ............ still learning this software.
Mofosheee
Return to VCarve - General
Users browsing this forum: dwilli9013, IslaWW, Majestic-12 [Bot] and 40 guests
