Groups
Groups
Postby Joeshark » Mon Feb 12, 2018 10:15 pm
How can I fix this. I cant seem to figure it out. Thanks
Joeshark
Model of CNC Machine: CNC Shark HD4
Re: Groups
Postby wbrock » Mon Feb 12, 2018 11:11 pm
I haven't used that font myself, but when do V carved lettering I end up using the fluting tool path. I'm sure there's a better way to do it and someone that knows how will chime in.
wbrock
Model of CNC Machine: piranha fx
Re: Groups
Postby Adrian » Mon Feb 12, 2018 11:23 pm
If you're VCarving script text and you enter it using the VCarve text tool there's no need to do anything as the VCarve toolpath will handle the overlaps etc.
If the text is vectors (either imported or created by converting text to curves) then you need to make sure that there are no overlaps between the letters and they all flow together. The tools to use in that scenario are the Weld too and the Interactive Trim tool.
Re: Groups
Postby Joeshark » Tue Feb 13, 2018 2:34 pm
Thanks Adrian, I’ll try your suggestions.
Joeshark
Re: Groups
Postby Joeshark » Tue Feb 13, 2018 2:40 pm
Wbrock, thanks for your suggestion. I have never used the fluting tool path so far. Is there any differents between the tool paths. Do you use a v-bit with the fluting tool path.
Joeshark
Re: Groups
Postby sharkcutup » Tue Feb 13, 2018 3:42 pm
(V-Carve Version 8.5) Brock Script 0.5" dia x 60 deg V-Bit
No Problem Here
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: hoganscnccrafts.com
V-Carve Pro 9.511
sharkcutup
Re: Groups
Postby Joeshark » Tue Feb 13, 2018 3:55 pm
Thanks sharkcutup Where do you think I ran into problems?
Joeshark
Re: Groups
Postby wbrock » Tue Feb 13, 2018 7:12 pm
Depends on the look I'm after. If want a fancier look I use the V bit, for a plain jane look I use a 1/16" end mill
wbrock
Re: Groups
Postby sharkcutup » Wed Feb 14, 2018 1:16 am
Can you post the .crv file? I would like to review what you have to see if I can resolve your problem?
Sharkcutup
V-Carve Pro 9.511
sharkcutup
Re: Groups
Postby Adrian » Wed Feb 14, 2018 11:05 am
Where did the text come from? Create it in VCarve with the text tool and you won't have any issues.
Re: Groups
Postby Joeshark » Wed Feb 14, 2018 1:29 pm
I’ll try that, I have carved block letters. This was the first time with script.
Joeshark
Re: Groups
Postby martin54 » Thu Feb 15, 2018 1:58 am
So was this text that you created in another software & then imported into Vcarve as Vectors?
As long as your fonts are in the windows font folder they will be shown in Vcarve, if it's just a straight line of text rotated 90 degrees it's easy enough to just use Vcarve to create it as Adrian says :lol: :lol:
Re: Groups
Postby Joeshark » Fri Feb 16, 2018 1:25 pm
Thanks guys, I used a different kind of fonts. Worked out just fine.
Joeshark
Return to VCarve - General
Users browsing this forum: Google [Bot], wmgeorge and 31 guests
