Ring Box
- mboydraska
- Model of CNC Machine: 3 axis homebuilt
Ring Box
Thought I would try something small. This ring box is 1.5 x 1.5 inches. Both halves are 3/4in material. My wife wanted a few for christmas gifts (daughters love jewelry) So now I have many to get done before Christmas now.
HAPPY CUTTING
Mike
Mike
- metalworkz
Re: Ring Box
Hi Mike,
The small jewelry box looks great! I need to make some more gifts and something like this would make a great gift. Thanks for posting the picture.
- glenn
- Model of CNC Machine: home brew 40x20
Re: Ring Box
Mike,
Yes, a wonderful idea!
what finish will you use- if any?
Thanks, Glenn
Thanks, Glenn
- mboydraska
Re: Ring Box
Thanks guys for the kind words, I will stain / apply a clear poly on a few others will leave natural with a clear poly. Made the mistake and showed off these to my brother in law now more is needed. They will make great gifts. Happy cutting!
Mike
Mike
HAPPY CUTTING
Mike
Mike
- dasch
Re: Ring Box
That is a cool little box. I don't think I've seen that design cut so small before. It actually holds up design-wise. I wonder if you should rub a little stain into the recesses and off; just to enhance the carving a little.
3D-ish
Dasch's VectorArt3D Models
Re: Ring Box
Great design! Can you tell me how you incorporate the hearts that are 3-D? I thought you could only do that if you had Aspire?
Mick
Mick
- RoutnAbout
Re: Ring Box
Mick,
You can use the Free 3D Machinist with any of VectorArt3D files.
Once you create the tool path, save the file, then you can import the file in to Cut2D or Vcarve Pro
- JamesB
- Vectric Alumni
Re: Ring Box
The current version of 3D Machinist will not create files that open in Cut2D, if you want to combine the 3D in 2D you need the old version which you can get from me if you drop me an email and I can send the link: jab (@) carve3d ( dot) com
James
James
- RoutnAbout
Re: Ring Box
Mick and James,JamesB wrote:The current version of 3D Machinist will not create files that open in Cut2D, if you want to combine the 3D in 2D you need the old version which you can get from me if you drop me an email and I can send the link: jab (@) carve3d ( dot) com
James
My apologies,
I didn't do all my homework.
Again sorry about the bad post Mick.
- mboydraska
Re: Ring Box
Attached is a few more of the ring boxes, some stained no clear coat yet. Some of the the images were done in PhotoVcarve. I drew the cross in my cad program then saved as a bitmap, sent to paint added some color for height. The Budda was an image I found on the net, the flowers are from VectorArt 3d. Those were generated in the old machinist program to send to Cut2d. I like the new program with the addition of resizing in different directions but like to be able to send to cut2d The Budda was cut with 60deg engraving bit from Bits&Bits dot com. The step over was 2%. Can't remember how long it took to run but the detail was worth it. All others were done with 1/16 ball nose at 6% step over if memory serve me correctly. (done so many different projects lately can't remember all)
HAPPY CUTTING
Mike
Mike
Re: Ring Box
I should have mentioned I'm currently running V-carve pro.....So is it the same process?
Mick
Mick
- mboydraska
Re: Ring Box
Mick,
it should be the same as cut2d, but don't take my word for it. i am not familiar with VcarvePro. (only have cut2d, photovcarve plus 3d machinist from vectorart3d) the models are imported into cut2d after saving a model/gcode. (I use the old 3d machinist program. But if I use the new one I set perimeters for the size of project. One of many things I like about the Vectric programs is ease of use.
HAPPY CUTTING
Mike
Mike
- mboydraska
Re: Ring Box
If anyone is interested attached is the crv file for the ring box (with no graphics)
- ring_box.crv
- ring box crv file
- (277 KiB) Downloaded 702 times
HAPPY CUTTING
Mike
Mike
