Page 1 of 1
Here's your sign.
Posted: Fri Sep 18, 2009 1:17 am
by indycraft
My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
- My first sign letters. Vectric Cut 2D makes this job easy.
Re: Here's your sign.
Posted: Fri Sep 18, 2009 1:31 am
by RoutnAbout
Those letters look crisp and sharp. Great Job...
200 pieces should keep you busy for a while!!!
Posted: Fri Sep 18, 2009 2:24 am
by indycraft
RoutnAbout wrote:Those letters look crisp and sharp. Great Job...
Thank you. Yeah with my small machine it does take a while as I don't like to run it faster than 50 ipm. Corners get rounded if I do. I told him he could probably buy them for less than I can make them but.......he likes me.........and he'll have no cash out as he will credit my rent. I like that.
Posted: Tue Oct 27, 2009 6:43 pm
by Joe Bloggs
indycraft wrote:My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
If you are using MACH 3, go into Config-general config, lower right hand corner-positive stop on angle, and enter a degree angle, then you can run faster and not get rounder corners.
Posted: Mon Nov 02, 2009 4:18 pm
by indycraft
stoneyreef wrote:indycraft wrote:My landlord needs new signs. He is moving his automotive repair business into a new building. He has piles of styrofoam he purchased from a roofing company up to 6 inches thick. So I have been planing the foam to thickness with the hot wire and cutting it up. I have to make over 200 characters 10"x1" or 23"x1.5" or 23"x3". He is going to paint the letters and mount them himself and I am glad for that. While I am not a sign maker the Vectric Cut 2D has made this job a snap.
Thank you for this information. I do use Mach 3 and will check it out.
Posted: Wed Jan 20, 2010 3:48 pm
by indycraft
I ended up making the entire sign. The frame is 46'7" long and 34" tall. I built the frame in two pieces. We finally got around to mounting it yesterday.
Posted: Thu Jan 21, 2010 7:40 pm
by mikeacg
You do good work! Thanks for sharing!
Posted: Thu Jan 28, 2010 5:00 am
by indycraft
mikeacg wrote:You do good work! Thanks for sharing!
Thank you.
Posted: Thu Jan 28, 2010 5:12 am
by metalworkz
Hello,
the sign looks great! Thanks for posting the follow up and picture.
Posted: Thu Jul 08, 2010 6:08 pm
by indycraft
If you are using MACH 3, go into Config-general config, lower right hand corner-positive stop on angle, and enter a degree angle, then you can run faster and not get rounder corners.[/quote]
I did do this this and it is working great. Thank you.
bart
Posted: Thu Jul 08, 2010 9:35 pm
by GaryR6
How was the waste material, ie were you using a vac system? Any issues with static charge when cutting the foam?
Posted: Fri Jul 09, 2010 1:14 pm
by indycraft
GaryR6 wrote:How was the waste material, ie were you using a vac system? Any issues with static charge when cutting the foam?
It was messy. I didn't use my dust shoe...not sure why I didn't. I blew the waste off the machine as I was cutting. The waste was charged and clung if I didn't blow it off.
I am glad I don't work with foam on a regular basis. This was a one time project.
Bart
Posted: Tue Dec 06, 2011 7:49 pm
by LouF
The sign looks great a very good looking sign..
