Hi folks,
I have been using cut2d for a few months now. The parts were cut on a Syil Sx3.
Milling is a completely new game for me, so any comments and sugestions regarding finish are more than welcome.
Most of the parts I cut are Aluminium, and on occasion, Acetal POMc
A few bit and pieces
- mboydraska
- Model of CNC Machine: 3 axis homebuilt
- RoutnAbout
Re: A few bit and pieces
Looks like you've got a really good handle on your aluminum and plastic work.byron wrote:Hi folks,
Finish also looks good. Great Job.
- metalworkz
Hi Byron,
Great looking parts you have made with your SX3! The finish looks very good for the most part on your parts! I can see the pass layers on the side of the thick part, but I am also usually seeing those pass marks on the edges of my parts. I think if needed we could implement a seperate 'finish' pass in our toolpaths to elimnate those marks, but for most items it is not necessary. I too am using the Syil SX3 and I just got my spindle back into working order last weekend. Thanks for posting the pictures for us to see, and keep them coming!
- Greasetattoo
Hi Matelworx,
The layering seen on the 25mm Sq Aluminium part is not "layering" as such. It was cut using a 12mm roughing end mill. The spindle was spun up to 3200 RPM and was fed through the material using a pass depth of 3mm at a fedd rate of 80mm / minute. Total cutting time, excluding holes, was just under half an hour. I did include a "finish" pass, if you can call it that with that type of tool. I had to make 12 off, and the finish was not that important, so I opted to use the roughing tool only, to try and save a little time. It is an electrical connector component. No Idea what it really does, my customer supplied the drawings. I can say, that I did under quote. I didn't figure it would take almost an hour to produce one part.
