Illuminated name
The Gallery is for posting photographs and images of work machined using Cut2D
Jay C
Illuminated name
Post by Jay C »
Used Cut2D to engrave a child's name in cast acrylic.
Tool used: 60-deg carbide V-bit
DOC: total .125"
After the part was cut out, use 220grit, then 800 grit sandpaper to smooth and polish edges. Simple circuit using 6 super bright LEDs wired in serial to a switch and current limited to 20mA.
Jay
nameplate
nameplate
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Post by metalworkz »
Hi Jay,
The illuminated sign turned out very good! Where are the lights located?
Thanks for posting the information and picture.
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
Jay C
Post by Jay C »
Lights are underneath. Here is the first sign I did for my son. The letters are completely routed out so the effect is diminished. I uses a bamboo drawer organizer as the "base".
I have plans to mix the acrylic with some nice wood to make a sign for my sons therapist ... he deserves it :)
Oh, and the Evan sign was my first ever CNC ... it use Lexan and I stupidly peeled the protective paper before milling.
Jay
Thkoutsidthebox
Re: Illuminated name
Post by Thkoutsidthebox »
Those are REALLY nice. :) Something I'm going to copy at some point if you dont mind?
