Page 1 of 1
Paradice box
Posted: Sat Feb 04, 2017 4:25 pm
by Paterson76
Can I make one smaller
metalmagot
Re: Paradice box
Posted: Sat Feb 04, 2017 6:45 pm
by Mark's Wood Chips
Metalmagot:
You can scale projects to any size you want, up or down. The caveat is that you must carefully examine all re-scaled dimensions and make adjustments for the thickness of your material. For example, the paradise box has tenon pockets that must be adjusted manually after you re-scale. Same with the fit of the cover and hinges.
Mark
Re: Paradice box
Posted: Sun Feb 05, 2017 12:31 pm
by Paterson76
Thanks for your reply Mark, I will give it a try
Regards.
Metalmagot.
