by Mark's Wood Chips » Sat Feb 04, 2017 6:45 pm
Metalmagot:
You can scale projects to any size you want, up or down. The caveat is that you must carefully examine all re-scaled dimensions and make adjustments for the thickness of your material. For example, the paradise box has tenon pockets that must be adjusted manually after you re-scale. Same with the fit of the cover and hinges.
Mark
