3d mesh pitbull edge lit sign
Re: 3d mesh pitbull edge lit sign
Postby Xxray » Fri Mar 14, 2014 2:47 am
No one can accuse me of lack of variety Mick, thats for sure.
To me thats part of the beauty of CNC + software, you can basically try anything you want and only risk a few $$ of materials and a little time if it doesn't pan out.
Doug
Xxray
Postby lbetancourt » Tue Jul 29, 2014 4:11 pm
Hi, beautiful work. What software do you use to create the mesh vectors?
lbetancourt
Model of CNC Machine: 1220x2440 3 axis
Postby Xxray » Wed Jul 30, 2014 4:42 am
Thanks, I either did it with aspire or used vector magic, I forgot which but either is more than capable
Doug
Xxray
Postby dataway » Mon Sep 08, 2014 10:02 pm
Xxray,
Your work is amazing in both detail and clarity...very impressed....
I would like to give this a try and was wondering what Diamond Drag bit are you using to get such great results?
Thanks....
dataway
Model of CNC Machine: Shapeoko 2
Postby Xxray » Mon Sep 08, 2014 10:17 pm
Thanks, this is the one I use
http://www.ebay.com/itm/1-4-DIA-DIAMOND ... 4186889623
Reasonably priced, tip lasts near forever, etches a variety of surfaces and capable of great detail.
Might want to consider an extra tip at time of purchase anyhow, they will wear eventually and you'll save on shipping]
Doug
Xxray
Postby pops1964 » Tue Sep 09, 2014 1:01 pm
XRAY , your work is looking great as always , I just did my first two acrylic signs and I'am hooked now this is way better than doing litho's . And I'am going to order that drag bit you suggested . Did you just change your bases ? I like the wrap around lights . And the mesh is very impressive. Pop's :)
POPS1964
SHOPBOT Buddy BT-32
pops1964
Model of CNC Machine: shopbot buddy bt 32
Postby nicksilva » Tue Sep 09, 2014 1:29 pm
The wire meshes look great. Very unique.
"Out of my mind. Back in 5 Minutes."
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Postby Xxray » Fri Sep 12, 2014 9:19 pm
No my bases are the same, I did make a few round "bases" for clocks, just a circular frame with the plexi surrounded by lights so that it can be hung.
Other than that, same old basic design.
Doug
Xxray
Postby nigelkdx200 » Tue Sep 30, 2014 1:06 am
XRAY your work is very detailed! Also, Thank you for providing details about how they were done! Would it be possible to share any of your drawings so that I could have a go at them?
nigelkdx200
Postby Xxray » Tue Sep 30, 2014 7:54 pm
Could probably be arraigned, would have to do some digging for those files.
Send a pm if able, could be copyright issues here better off not posted in open forum.
Doug
Xxray
Postby pops1964 » Mon Oct 13, 2014 11:42 pm
Xray thank for the acrylic info Ron set me up and is shipping right to the house . Better deal on acrylic & shipping than estreets. Thanks Pop's :mrgreen:
POPS1964
SHOPBOT Buddy BT-32
pops1964
Postby Xxray » Mon Oct 13, 2014 11:56 pm
Ron is a great guy, if you are ever around the area stop in the shop [make sure to coordinate to make sure he is there, he is out and about alot].
You will be amazed at the things hes got, his shop is like a stairway to heaven its that good.
Doug
Xxray
Postby antennasDIY » Mon Dec 08, 2014 6:09 pm
Xray, I can't seem to select the diamond drag bit when I try to use a pocket tool path or a profile tool path. Can you help me out with this? I just got it and am just trying some lines as a test but I can't select the tool.
Can you post an example if you were to cut a circle or square or something easy just to get me going please?
Thanks.
antennasDIY
Model of CNC Machine: Home made
Postby antennasDIY » Mon Dec 08, 2014 7:37 pm
I found this from Google..not the Vectric search...hmmm oh well but it helped explain what you are doing. Thanks.
viewtopic.php?f=27&t=20074
antennasDIY
Postby antennasDIY » Mon Dec 08, 2014 11:11 pm
Here are the results I have so far. Have a look and feel free to suggest improvements please. I would only like it to be filled better so it looks more smooth. I guess just a smaller stepover?
Oh and the maple leaf has a real difference in contrast, depending on bit direction it seems. As part of the leaf stands out more than the other. What would cause that?
Do you run the file more than once to get more depth?
Thanks.
acrylic diamond drag
rcmp acrylic diamond drag
Airborne acrylic diamond drag
antennasDIY
PreviousNext
Return to Cut2D - Gallery
