Swan in pink swirled Corian
Postby IBBruin » Thu Apr 26, 2012 12:19 am
The swan was downloaded from Vectrics 3D models and tool path generated in V3 Machinist. After importing the toolpath into cut2D I did the layout geometry and depth of cut. I decided not to polish this to a glossy shine. I used 220 grit paper on an orbital sander with a very light finishing pass which gave it the look and soft feel of a bar of soap. I've seen some unbelievable things produced by others that I can't hold a candle to but this is probably the finest piece of art I've created with my home made cnc router.
This will be my first post on this forum so I hope the picture shows up.
IBBruin
Model of CNC Machine: Homegrown
Re: Swan in pink swirled Corian
Postby tmerrill » Thu Apr 26, 2012 12:30 am
I think it looks great and you should be pleased.
Welcome to the forum and I hope to see more of your projects in the future.
Tim
tmerrill
Model of CNC Machine: ShopBot
Postby IBBruin » Thu Apr 26, 2012 12:32 am
I gave it away to a friend. Now the wife wants one. Is there no end? lol
IBBruin
Postby Rcnewcomb » Thu Apr 26, 2012 12:39 am
It looks much better than my first attempt at a swan in marble. You should be very proud.
Postby jimwill2 » Thu Apr 26, 2012 1:44 am
Very nice work!
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Postby ailmik » Thu Apr 26, 2012 2:14 am
Top job IBBruin. Question thou, how do you normally go about polishing corian?
Regards
Kim
ailmik
Model of CNC Machine: Joe's Hybrid
Postby IBBruin » Thu Apr 26, 2012 2:40 am
I chuck up a 4 inch cotton wheel in my drill press, set the spindle rpm to max and use some green polishing compound I get at Harbor Freight. It's time consuming but you can even get the rough side of corian polished pretty well.
IBBruin
Postby ailmik » Thu Apr 26, 2012 10:24 pm
Excellent. Thanks for the tip.
Cheers
ailmik
Postby GaryR6 » Thu Apr 26, 2012 10:59 pm
Nice and thanks for the tip on polishing..... I just got some cut offs I'll give a try.
GaryR6
Postby zeeway » Fri Apr 27, 2012 11:40 am
Beautiful work.
Angie
zeeway
Postby IBBruin » Sat Apr 28, 2012 1:46 am
Thank you all for the kind words.
Rcnewcomb, I'd be proud if my first attempt looked as good as yours.
IBBruin
Return to Cut2D - Gallery
