Hi,
Is there a way to put in a dovetail cutter for undercutting in Cut2D? If not I will just give the cutting diameter at the 0 point and call it a endmill. What I need to do is have a 10 deg undercut around a pocket. I will draw it seperatly and do one pass with a inside profile. The largest diameter of the cutter will be 0.25 dovetail bit.
Jon
Dovetail cutter
Re: Dovetail cutter
I believe this has come up before and the answer was no.
Jason
Jason
The Official Vectric Cartographer
You are limited only by your imagination
Re: Dovetail cutter
As Jason stated, there are no provisions in the software for a dovetail....But, I use one all the time, I cut a pocket in the backside of wall plaques and then undercut the top edge with a dovetail. Something to hang the nail head on. My profile cut thinks it's a endmill cutting inside the vector. Make sure you start in the middle at depth of the pocket and go to the vector perimeter and then return to the middle before the z raises. You can lead in and out to do this.Jon_sparky wrote:Hi,
Jon
- Model of CNC Machine: shobot 48x96
Re: Dovetail cutter
make your file easier get a bit just for that. ti is really just a t slot bit but smaller. freud makes them. that way no bit changes.CRFultz wrote:[
Re: Dovetail cutter
Hi,
Thanks for the input. I don't see how a T slot cutter will give me a 10 deg dovetail cut. I did find a 1/4" dovetail, so I will be able to cut the whole pocket with the dovetail cutter in one shot.
Jon
Jon
- tamathumper
Re: Dovetail cutter
Is there a lead in/out function I haven't noticed yet, or are you making a trapezoid from a node-edited rectangle, or... ?Make sure you start in the middle at depth of the pocket and go to the vector perimeter and then return to the middle before the z raises. You can lead in and out to do this.
CNC: www.bitcarving.com; Hybrid 4x4, RockCliff, Mach3, Vectric Aspire 2 + Wildlife Scenes 1.
Re: Dovetail cutter
No lead in / out options in Cut2D.
You will need to draw / node edit the center-line for the toolpath and include the lead portions.
Then toolpath using Profile = On the selected vector
Tony
Tony
- tamathumper
Re: Dovetail cutter
Yep, gotcha. Thanks Tony!
Re: Dovetail cutter
Not a problem, I made the pocket a little longer, so the exit will be in the waste material area. The shape of the pocket, lends itself to be cut from the center outward. I just got the English Sycamore and the 1/4" dovetail today, worked great!
Jon
Jon
